跳转到主内容
Crayola Crayon Maker Sliding Lock Mechanism Replacement
你所需要的
  1. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: 步骤 1 中的图像 1,3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: 步骤 1 中的图像 2,3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Take out the melting tray that is out of place.: 步骤 1 中的图像 3,3
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: 步骤 2 中的图像 1,3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: 步骤 2 中的图像 2,3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the metal melting tray.: 步骤 2 中的图像 3,3
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: 步骤 3 中的图像 1,3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: 步骤 3 中的图像 2,3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the light bulb: 步骤 3 中的图像 3,3
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
  4. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: 步骤 4 中的图像 1,3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: 步骤 4 中的图像 2,3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Remove the green base from the crayon maker: 步骤 4 中的图像 3,3
    • Flip the crayon maker.
    • Remove six screws (2 cm in length) with a spanner.
    • Remove the green base plate and set it aside.
  5. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: 步骤 5 中的图像 1,3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: 步骤 5 中的图像 2,3 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Locate the Plastic arm: 步骤 5 中的图像 3,3
    • Locate the clear plastic arm inside the control box.
  6. Crayola Crayon Maker Sliding Lock Mechanism Replacement, Adjust/Replace the Plastic Arm: 步骤 6 中的图像 1,2 Crayola Crayon Maker Sliding Lock Mechanism Replacement, Adjust/Replace the Plastic Arm: 步骤 6 中的图像 2,2
    • If necessary, unscrew the plastic arm with a Phillips #00 Precision screwdriver and readjust the arm until the desired position is reached.
    • If the plastic arm is broken, contact Crayola for replacement parts.
结论
Heidi Clarke
于09/21/14注册
222 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 662
