跳转到主内容
Crayola Crayon Maker Light Bulb Removal and Replacement
你所需要的
  1. Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: 步骤 1 中的图像 1,3 Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: 步骤 1 中的图像 2,3 Crayola Crayon Maker Light Bulb Removal and Replacement, Take out the melting tray that is out of place.: 步骤 1 中的图像 3,3
    • Press the green arm away from the melting tray. Remove the melting tray.
    • Pop the metal arms out of the green pivot support.
  2. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: 步骤 2 中的图像 1,3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: 步骤 2 中的图像 2,3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the metal melting tray.: 步骤 2 中的图像 3,3
    • Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
  3. Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: 步骤 3 中的图像 1,3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: 步骤 3 中的图像 2,3 Crayola Crayon Maker Light Bulb Removal and Replacement, Remove the light bulb: 步骤 3 中的图像 3,3
    • The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
终点
另外一个人完成了本指南。
Heidi Clarke
于09/21/14注册
222 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 36
总计 6,183
