简介
pre-req guide on opening the crankcase cover in preparation for service inside the crankcase chamber
你所需要的
Elevate the generator on a set of stable risers, like wooden blocks.
Place a drain pan underneath the generator, between the blocks.
Use a 12 mm socket to remove the oil drain plugs from either side of the generator.
Give the oil a few minutes to drain from the cylinder and crankcase housing.
Once the oil is finished draining, replace the drain plugs.
Use a 12 mm socket to remove the two 20 mm-long bolts securing the shaft guard to the crankcase cover.
Remove the shaft guard.
Use a 12 mm socket to remove the six 32 mm-long bolts securing the crankcase cover.
Use a 12 mm socket to remove the nut securing the upper cylinder shroud and air guide plate.
Use a 10 mm socket to remove the 12 mm-long bolt securing the air guide plate.
Remove the air guide plate.
When the shroud is sufficiently out of the way, remove the crankcase cover.
