跳转到主内容
Craig Electronics CMP773 Volume/Power Control Button Replacement
你所需要的
  1. Craig Electronics CMP773 Volume/Power Control Button Replacement, Volume/Power Control Button: 步骤 1 中的图像 1,1
    • Remove the two 3.2 mm PH000 screws near the charging port.
  2. Craig Electronics CMP773 Volume/Power Control Button Replacement: 步骤 2 中的图像 1,1
    • Pry the back cover from the device along bottom edge.
  3. Craig Electronics CMP773 Volume/Power Control Button Replacement: 步骤 3 中的图像 1,1
    • Continue prying along each edge of the device until back cover is free.
  4. Craig Electronics CMP773 Volume/Power Control Button Replacement: 步骤 4 中的图像 1,1
    • On the back cover, find the location where the volume/power button is held.
    • The volume/power button is not held securely after back is removed so it may fall out of place while removing the back cover from the device.
  5. Craig Electronics CMP773 Volume/Power Control Button Replacement: 步骤 5 中的图像 1,2 Craig Electronics CMP773 Volume/Power Control Button Replacement: 步骤 5 中的图像 2,2
    • Remove the old button and replace it with the new one.
结论
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced volume/power control button.
Jessie L Morris
于03/26/18注册
171 声望
撰写一个指南
团队
IUPUI, Team S1-G5, Harley Spring 2018 IUPUI, Team S1-G5, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S1G5
6 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 248
