跳转到主内容
加入维修社区 - 创建账户
Craig Electronics CMP773 Screen Replacement
你所需要的
  1. Craig Electronics CMP773 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Craig Electronics CMP773 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Remove two screws on the charging port side of the tablet using the Phillips #00 screwdriver.
  2. Craig Electronics CMP773 Screen Replacement: 步骤 2 中的图像 1,3 Craig Electronics CMP773 Screen Replacement: 步骤 2 中的图像 2,3 Craig Electronics CMP773 Screen Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool between the screen and the back of the tablet.
    • Insert another opening tool along the same side of the tablet and pry them in opposite directions until the casing pops.
    • Once roughly half of the case has been unlatched, it can be removed by hand.
  3. Craig Electronics CMP773 Screen Replacement: 步骤 3 中的图像 1,2 Craig Electronics CMP773 Screen Replacement: 步骤 3 中的图像 2,2
    • Use the spudger to gently pry the camera from the casing.
  4. Craig Electronics CMP773 Screen Replacement: 步骤 4 中的图像 1,2 Craig Electronics CMP773 Screen Replacement: 步骤 4 中的图像 2,2
    • Using your finger, remove the clamp that connects the screen power rib to the motherboard.
    • Using needle nose pliers, remove the ribbon.
  5. Craig Electronics CMP773 Screen Replacement: 步骤 5 中的图像 1,3 Craig Electronics CMP773 Screen Replacement: 步骤 5 中的图像 2,3 Craig Electronics CMP773 Screen Replacement: 步骤 5 中的图像 3,3
    • Remove the second screen power connection from the motherboard using the same procedure as step 4.
  6. Craig Electronics CMP773 Screen Replacement: 步骤 6 中的图像 1,3 Craig Electronics CMP773 Screen Replacement: 步骤 6 中的图像 2,3 Craig Electronics CMP773 Screen Replacement: 步骤 6 中的图像 3,3
    • Remove four screws from the motherboard using the Phillips #00 screwdriver.
  7. Craig Electronics CMP773 Screen Replacement: 步骤 7 中的图像 1,2 Craig Electronics CMP773 Screen Replacement: 步骤 7 中的图像 2,2
    • Remove a single screw from the speaker using the Phillips #00 screwdriver.
    • Pry up on the locking tabs with the flat spudger.
  8. Craig Electronics CMP773 Screen Replacement: 步骤 8 中的图像 1,1
    • Using needle nose pliers, remove the ground wire from the casing.
  9. Craig Electronics CMP773 Screen Replacement: 步骤 9 中的图像 1,1
    • Using the plastic opening tool, remove the battery.
  10. Craig Electronics CMP773 Screen Replacement: 步骤 10 中的图像 1,2 Craig Electronics CMP773 Screen Replacement: 步骤 10 中的图像 2,2
    • With all screws and components removed, gently remove the motherboard from the casing.
  11. Craig Electronics CMP773 Screen Replacement: 步骤 11 中的图像 1,3 Craig Electronics CMP773 Screen Replacement: 步骤 11 中的图像 2,3 Craig Electronics CMP773 Screen Replacement: 步骤 11 中的图像 3,3
    • Insert the spudger in between the screen and case. Work your way around the outside of the screen.
  12. Craig Electronics CMP773 Screen Replacement: 步骤 12 中的图像 1,3 Craig Electronics CMP773 Screen Replacement: 步骤 12 中的图像 2,3 Craig Electronics CMP773 Screen Replacement: 步骤 12 中的图像 3,3
    • Grasp the exposed screen corner and gently separate the screen from the housing.
结论
Justin mersch
于11/07/19注册
205 声望
撰写一个指南
团队
IUPUI, Team S3-G4, Harley Fall 2019 IUPUI, Team S3-G4, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S3G4
4 名成员
创作了3篇指南
1指南评论
What kind of battery does this device specifically use
Kris Miller - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 338
