跳转到主内容
Craig Electronics CMP773 Front and Rear Camera Replacement
你所需要的
  1. Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 1 中的图像 1,2 Craig Electronics CMP773 Front and Rear Camera Replacement, Front and Rear Camera: 步骤 1 中的图像 2,2
    • Remove the two Phillips #00 screws from the bottom of the screen.
  2. Craig Electronics CMP773 Front and Rear Camera Replacement: 步骤 2 中的图像 1,2 Craig Electronics CMP773 Front and Rear Camera Replacement: 步骤 2 中的图像 2,2
    • Insert a plastic opening tool underneath the screen.
    • Once the first tool is inserted, insert another opening tool along the same side of the tablet.
    • Pry them in opposite directions until the casing pops.
  3. Craig Electronics CMP773 Front and Rear Camera Replacement: 步骤 3 中的图像 1,2 Craig Electronics CMP773 Front and Rear Camera Replacement: 步骤 3 中的图像 2,2
    • Move the opening tool along the edge of the tablet to continue popping the casing loose.
    • Once the casing is about half loose, remove it by hand.
  4. Craig Electronics CMP773 Front and Rear Camera Replacement: 步骤 4 中的图像 1,2 Craig Electronics CMP773 Front and Rear Camera Replacement: 步骤 4 中的图像 2,2
    • Remove the tape from the power connection for the camera unit.
    • Unhinge the clamp on the camera power connection to expose the removable plug.
  5. Craig Electronics CMP773 Front and Rear Camera Replacement: 步骤 5 中的图像 1,1
    • Gently remove the power ribbon from the connector.
  6. Craig Electronics CMP773 Front and Rear Camera Replacement: 步骤 6 中的图像 1,2 Craig Electronics CMP773 Front and Rear Camera Replacement: 步骤 6 中的图像 2,2
    • Use the spudger to dislodge camera unit from the casing and remove it from the device.
结论
Luke VanLangevelde
于11/07/19注册
133 声望
撰写一个指南
团队
IUPUI, Team S3-G4, Harley Fall 2019 IUPUI, Team S3-G4, Harley Fall 2019 的会员
IUPUI-HARLEY-F19S3G4
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 157
