跳转到主内容
Craig Electronics CMP773 Battery Replacement
你所需要的
  1. Craig Electronics CMP773 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the two 3.2 mm PH000 screws near the charging port.
  2. Craig Electronics CMP773 Battery Replacement: 步骤 2 中的图像 1,1
    • Pry the back cover from the device along the bottom edge.
  3. Craig Electronics CMP773 Battery Replacement: 步骤 3 中的图像 1,1
    • Continue prying along the edge of the device until the back cover is free.
  4. Craig Electronics CMP773 Battery Replacement: 步骤 4 中的图像 1,1
    • Pry the battery free from the device using a plastic opening tool.
  5. Craig Electronics CMP773 Battery Replacement: 步骤 5 中的图像 1,1
    • Desolder the faulty battery wires.
  6. Craig Electronics CMP773 Battery Replacement: 步骤 6 中的图像 1,1
    • Solder the replacement battery wires to the circuit board.
  7. Craig Electronics CMP773 Battery Replacement: 步骤 7 中的图像 1,1
    • Apply adhesive between the replacement battery and the device before installation.
结论
Once the above steps have been successfully competed, power on the device. Enjoy your newly replaced battery.
Jacob Hampton
于03/26/18注册
145 声望
撰写一个指南
团队
IUPUI, Team S1-G5, Harley Spring 2018 IUPUI, Team S1-G5, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S1G5
6 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 256
