简介
In order to replace the LCD screen you must remove all the other parts, starting from the back panel.
你所需要的
Locate the opening line between the cover and the device. Then locate the groove near the charging port.
After taking out the back cover, locate the black flap.
Open the black flap with the plastic opening tools.
在这个步骤中使用的工具:Tweezers$3.99
Once the tab is released, use the angled tweezers to take out the tab.
Locate the white plug next to the battery.
Use your fingers to pull off white plug that connected to the battery.
另外一个人完成了本指南。
