跳转到主内容
加入维修社区 - 创建账户
Craig CMP801 LCD Screen Replacement
你所需要的
  1. Craig CMP801 LCD Screen Replacement, Back Cover: 步骤 1 中的图像 1,2 Craig CMP801 LCD Screen Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 LCD Screen Replacement: 步骤 2 中的图像 1,2 Craig CMP801 LCD Screen Replacement: 步骤 2 中的图像 2,2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 LCD Screen Replacement: 步骤 3 中的图像 1,2 Craig CMP801 LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 LCD Screen Replacement, Volume Controls: 步骤 4 中的图像 1,2 Craig CMP801 LCD Screen Replacement, Volume Controls: 步骤 4 中的图像 2,2
    • After taking out the back cover, locate the black flap.
    • Open the black flap with the plastic opening tools.
    • Be careful not to break the flap when you open it.
  5. Craig CMP801 LCD Screen Replacement: 步骤 5 中的图像 1,2 Craig CMP801 LCD Screen Replacement: 步骤 5 中的图像 2,2
    在这个步骤中使用的工具:
    $3.99
    • Once the tab is released, use the angled tweezers to take out the tab.
    • Be careful not to scratch the tab.
  6. Craig CMP801 LCD Screen Replacement: 步骤 6 中的图像 1,2 Craig CMP801 LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Use the angled tweezers to pull the volume controls out and replace it with a new one.
  7. Craig CMP801 LCD Screen Replacement, Battery: 步骤 7 中的图像 1,3 Craig CMP801 LCD Screen Replacement, Battery: 步骤 7 中的图像 2,3 Craig CMP801 LCD Screen Replacement, Battery: 步骤 7 中的图像 3,3
    • Locate the white plug next to the battery.
    • Use your fingers to pull off white plug that connected to the battery.
    • Be careful not to pull or break the wires on the bottom.
  8. Craig CMP801 LCD Screen Replacement: 步骤 8 中的图像 1,3 Craig CMP801 LCD Screen Replacement: 步骤 8 中的图像 2,3 Craig CMP801 LCD Screen Replacement: 步骤 8 中的图像 3,3
    • The battery should only be connected to the LCD by adhesive tape.
    • Using force, carefully remove the battery while holding the LCD in place.
  9. Craig CMP801 LCD Screen Replacement, LCD Screen: 步骤 9 中的图像 1,3 Craig CMP801 LCD Screen Replacement, LCD Screen: 步骤 9 中的图像 2,3 Craig CMP801 LCD Screen Replacement, LCD Screen: 步骤 9 中的图像 3,3
    • Open the three black flaps located on each side of the motherboard.
  10. Craig CMP801 LCD Screen Replacement: 步骤 10 中的图像 1,2 Craig CMP801 LCD Screen Replacement: 步骤 10 中的图像 2,2
    • Then detach each of the three tabs from the LCD screen.
  11. Craig CMP801 LCD Screen Replacement: 步骤 11 中的图像 1,2 Craig CMP801 LCD Screen Replacement: 步骤 11 中的图像 2,2
    • Using a Philips 0 Screwdriver, remove the screws connecting the speaker to the motherboard.
    • Remove black plastic speaker holder.
  12. Craig CMP801 LCD Screen Replacement: 步骤 12 中的图像 1,1
    • Remove the gray tape connecting the motherboard to the metal slate.
    • Use a spudger to separate the metal slate from the front touch screen.
  13. Craig CMP801 LCD Screen Replacement: 步骤 13 中的图像 1,2 Craig CMP801 LCD Screen Replacement: 步骤 13 中的图像 2,2
    • Carefully slide out the metal slate and LCD screen from underneath the motherboard.
  14. Craig CMP801 LCD Screen Replacement: 步骤 14 中的图像 1,1
    • Flip over the metal slate and separate the LCD screen from it.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 1,296
