跳转到主内容
Craig CMP801 Front and Rear Facing Camera Replacement
你所需要的
  1. Craig CMP801 Front and Rear Facing Camera Replacement, Back Cover: 步骤 1 中的图像 1,2 Craig CMP801 Front and Rear Facing Camera Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Front and Rear Facing Camera Replacement: 步骤 2 中的图像 1,2 Craig CMP801 Front and Rear Facing Camera Replacement: 步骤 2 中的图像 2,2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Front and Rear Facing Camera Replacement: 步骤 3 中的图像 1,2 Craig CMP801 Front and Rear Facing Camera Replacement: 步骤 3 中的图像 2,2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Front and Rear Facing Camera Replacement, Front and Rear Facing Camera: 步骤 4 中的图像 1,2 Craig CMP801 Front and Rear Facing Camera Replacement, Front and Rear Facing Camera: 步骤 4 中的图像 2,2
    • Once the back cover is removed, gently remove the black tape that covers the front and rear facing camera.
  5. Craig CMP801 Front and Rear Facing Camera Replacement: 步骤 5 中的图像 1,1
    • Near the edge of the device, lift up the tab connected to the front-facing camera.
  6. Craig CMP801 Front and Rear Facing Camera Replacement: 步骤 6 中的图像 1,2 Craig CMP801 Front and Rear Facing Camera Replacement: 步骤 6 中的图像 2,2
    • Locate the black flap that covers and holds down the tab connected to the rear-facing camera.
    • Flip the flap up to release the tab.
  7. Craig CMP801 Front and Rear Facing Camera Replacement: 步骤 7 中的图像 1,2 Craig CMP801 Front and Rear Facing Camera Replacement: 步骤 7 中的图像 2,2
    • Gently pull on the tab connected to the front-facing camera to release both the front and rear-facing cameras.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 12
总计 243
