跳转到主内容
加入维修社区 - 创建账户
Craig CMP801 Battery Replacement
你所需要的
  1. Craig CMP801 Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 Craig CMP801 Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Locate the opening line between the cover and the device. Then locate the groove near the charging port.
  2. Craig CMP801 Battery Replacement: 步骤 2 中的图像 1,2 Craig CMP801 Battery Replacement: 步骤 2 中的图像 2,2
    • Use a metal spudger to separate the back cover from the front touch screen.
    • To do this, place the metal spudger in between the groove near the charging port of the device to unlatch the first clip.
  3. Craig CMP801 Battery Replacement: 步骤 3 中的图像 1,2 Craig CMP801 Battery Replacement: 步骤 3 中的图像 2,2
    • Continue to separate all of the clips around the device until the back cover comes off completely.
  4. Craig CMP801 Battery Replacement, Battery: 步骤 4 中的图像 1,3 Craig CMP801 Battery Replacement, Battery: 步骤 4 中的图像 2,3 Craig CMP801 Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Locate the white plug next to the battery.
    • Use your fingers to pull off white plug that connected to the battery.
    • Be careful not to pull or break the wires on the bottom.
  5. Craig CMP801 Battery Replacement: 步骤 5 中的图像 1,3 Craig CMP801 Battery Replacement: 步骤 5 中的图像 2,3 Craig CMP801 Battery Replacement: 步骤 5 中的图像 3,3
    • The battery should only be connected to the LCD by adhesive tape.
    • Using force, carefully remove the battery while holding the LCD in place.
结论
2等其他人完成本指南。
1指南评论
Where do I find a battery cmp749 ???
kourriclay929 - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 16
过去 30 天: 41
总计 1,412
