跳转到主内容
Craftsman M215 Oil and Air Filter Replacement
你所需要的
  1. Craftsman M215 Oil and Air Filter Replacement, Oil and Air Filter: 步骤 1 中的图像 1,2 Craftsman M215 Oil and Air Filter Replacement, Oil and Air Filter: 步骤 1 中的图像 2,2
    • Remove the black plastic cover to the air filter using a screwdriver to remove the single screw that secures the cover.
  2. Craftsman M215 Oil and Air Filter Replacement: 步骤 2 中的图像 1,2 Craftsman M215 Oil and Air Filter Replacement: 步骤 2 中的图像 2,2
    • Take off the filter cover and determine whether the air filter needs to be replaced.
    • This Craftsman lawnmower uses a standard paper type filter. As you can see my filter is pretty clean but if it's in really rough shape, it's better to have it replaced.
  3. Craftsman M215 Oil and Air Filter Replacement: 步骤 3 中的图像 1,1
    • After making sure the area is clean, Reseat the air filter in its original compartment, ensuring it is positioned correctly.
    • Cover it by attaching the filter cover.
  4. Craftsman M215 Oil and Air Filter Replacement: 步骤 4 中的图像 1,1
    • Start the engine. It should be running smoothly compared to how it was before the filter change. If there's any persistent weird noise, check the filter to ensure it is seated properly.
    • Next, keep the engine running for approx. 5 to 10 minutes as the next step is to do the oil change. This will help to ensure the oil is warmed up so it drains easily.
  5. Craftsman M215 Oil and Air Filter Replacement: 步骤 5 中的图像 1,3 Craftsman M215 Oil and Air Filter Replacement: 步骤 5 中的图像 2,3 Craftsman M215 Oil and Air Filter Replacement: 步骤 5 中的图像 3,3
    • Clean the area around the oil cap with a towel or a cotton cloth.
    • Detach the spark plug wire if tilting the mower for drainage.[ It's located in the front of the lawnmower-right on the left hand side of the air filter].
    • Most Craftsman lawnmowers use SAE30 type engine oils. Oils used in automobile engines can also be used. Make sure you check what the user manual recommends for the oil grade and type.
  6. Craftsman M215 Oil and Air Filter Replacement: 步骤 6 中的图像 1,2 Craftsman M215 Oil and Air Filter Replacement: 步骤 6 中的图像 2,2
    • After removing the dipstick with the gray cap, place it on a paper towel and set aside.
    • Place the funnel in the pipe where the dipstick was located.
    • Also, make sure to have an empty container where the oil will be emptied out.
  7. Craftsman M215 Oil and Air Filter Replacement: 步骤 7 中的图像 1,3 Craftsman M215 Oil and Air Filter Replacement: 步骤 7 中的图像 2,3 Craftsman M215 Oil and Air Filter Replacement: 步骤 7 中的图像 3,3
    • Tilt the lawn mower on its side (where the air filter will face upwards), open the oil cap and allow the oil to flow into the container until the tank is empty.
    • While draining the oil, be careful as the hot oil can damage the skin.
    • In my case, the oil wasn't as bad so i put it back in using a funnel into the oil tank. But make sure to check the recommended oil type in the manual.
    • To make sure the oil is filled to the appropriate level, keep checking the oil level with the dipstick until you reach the right level.
  8. Craftsman M215 Oil and Air Filter Replacement: 步骤 8 中的图像 1,1
    • After the oil is filled to the appropriate level, close the gray cap and allow it to settle down. When you're done, clean the work area from any spills that occurred.
    • Make sure to put away tools appropriately and dispose of old oil and air filter appropriately as well.
结论
In the end, start the engine to ensure there's no oil leakage and the engine is running smoothly.
2等其他人完成本指南。
Mandeep Kaur
于07/02/21注册
205 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 70
过去 30 天: 357
总计 6,822
