跳转到主内容
Craftsman 944.360480 Carburetor O-Ring Replacement
你所需要的
  1. Craftsman 944.360480 Carburetor O-Ring Replacement, Carburetor O-Ring: 步骤 1 中的图像 1,1
    • Make sure your engine is completely shut down and cooled off prior to starting this repair.
    • Put gloves on, so you don’t get any oil or gasoline on your skin.
  2. Craftsman 944.360480 Carburetor O-Ring Replacement: 步骤 2 中的图像 1,1
    • Use a flathead screwdriver and remove the 40 mm screw that secures the air filter and the case to the lawn mower.
  3. Craftsman 944.360480 Carburetor O-Ring Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the air filter and set it aside.
  4. Craftsman 944.360480 Carburetor O-Ring Replacement: 步骤 4 中的图像 1,1
    • Slowly remove the air filter case from the hinges by tilting it slightly and pulling it out.
  5. Craftsman 944.360480 Carburetor O-Ring Replacement: 步骤 5 中的图像 1,1
    • Use the socket wrench and put the 5/16” inch hex bit on to remove the three 20 mm bolts located behind the air filter.
  6. Craftsman 944.360480 Carburetor O-Ring Replacement: 步骤 6 中的图像 1,1
    • Pull the plastic backing off which will expose the carburetor.
  7. Craftsman 944.360480 Carburetor O-Ring Replacement: 步骤 7 中的图像 1,2 Craftsman 944.360480 Carburetor O-Ring Replacement: 步骤 7 中的图像 2,2
    • Use utility pliers to pull out the fuel line slowly by wiggling it up and down.
    • Have a container ready to pour out any extra fuel left in the mower.
    • Be sure to put a cloth or rag under if you don’t want it spilling anywhere.
  8. Craftsman 944.360480 Carburetor O-Ring Replacement: 步骤 8 中的图像 1,1
    • Use the socket wrench with a ½” inch hex bit to remove the 11 mm screw on the bottom of the tank.
  9. Craftsman 944.360480 Carburetor O-Ring Replacement: 步骤 9 中的图像 1,2 Craftsman 944.360480 Carburetor O-Ring Replacement: 步骤 9 中的图像 2,2
    • Pull the carburetor tank down slowly.
    • Empty any extra gasoline and use a rag to clean it out.
  10. Craftsman 944.360480 Carburetor O-Ring Replacement: 步骤 10 中的图像 1,1
    • Remove the O-Ring from the carburetor tank and replace it with a new one. You are ready to reassemble your lawnmower!
结论
Priyum Mistry
于01/10/22注册
181 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 487
