当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Remove the fuel line from the fuel tank with pliers.
Take off the fuel cap and place a safe container under the fuel line.
Make sure to drain all of the fuel from the fuel tank into the container.
Remove the four support bolts on the top of the tank and motor with a crescent wrench or socket wrench.
Lift the fuel tank off of the lower supporting brackets.
Replace the cracked fuel tank and place the new one onto the lower supporting brackets.
Screw in the top four supporting bracket bolts with a crescent wrench or socket wrench to hold the new fuel tank in place.
Reconnect the fuel line and hose clamp.
Fill the tank with fuel.
Check to make sure that the hose clamp is not leaking.
取消:我没有完成这个指南。
与4其他贡献者
于10/07/19注册
169 声望
撰写一个指南
徽章: 2
EWU-MUNOZ-F19S27G14
1 名成员
创作了2篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 1,994
