跳转到主内容
Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank Replacement
你所需要的
  1. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement, Fuel Tank: 步骤 1 中的图像 1,2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement, Fuel Tank: 步骤 1 中的图像 2,2
    • Remove the fuel line from the fuel tank with pliers.
  2. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: 步骤 2 中的图像 1,2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: 步骤 2 中的图像 2,2
    • Take off the fuel cap and place a safe container under the fuel line.
    • Make sure to drain all of the fuel from the fuel tank into the container.
  3. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: 步骤 3 中的图像 1,2 Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: 步骤 3 中的图像 2,2
    • Remove the four support bolts on the top of the tank and motor with a crescent wrench or socket wrench.
  4. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: 步骤 4 中的图像 1,1
    • Lift the fuel tank off of the lower supporting brackets.
  5. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: 步骤 5 中的图像 1,1
    • Replace the cracked fuel tank and place the new one onto the lower supporting brackets.
  6. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: 步骤 6 中的图像 1,1
    • Screw in the top four supporting bracket bolts with a crescent wrench or socket wrench to hold the new fuel tank in place.
  7. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: 步骤 7 中的图像 1,1
    • Reconnect the fuel line and hose clamp.
  8. Craftsman 9.0 HP 26 Inch Snow Blower Fuel Tank  Replacement: 步骤 8 中的图像 1,1
    • Fill the tank with fuel.
    • Check to make sure that the hose clamp is not leaking.
结论
Megan Smith
于10/07/19注册
169 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 2,013
