跳转到主内容
加入维修社区 - 创建账户
Cracking the Case
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Cracking the Case, Cracking the Case: 步骤 1 中的图像 1,1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. Cracking the Case: 步骤 2 中的图像 1,1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. Cracking the Case: 步骤 3 中的图像 1,1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. Cracking the Case: 步骤 4 中的图像 1,2 Cracking the Case: 步骤 4 中的图像 2,2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. Cracking the Case: 步骤 5 中的图像 1,3 Cracking the Case: 步骤 5 中的图像 2,3 Cracking the Case: 步骤 5 中的图像 3,3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. Cracking the Case: 步骤 6 中的图像 1,1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. Cracking the Case: 步骤 7 中的图像 1,2 Cracking the Case: 步骤 7 中的图像 2,2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
结论
团队
Cal Poly, Team 9-28, Maness Winter 2014 Cal Poly, Team 9-28, Maness Winter 2014 的会员
CPSU-MANESS-W14S9G28
4 名成员
创作了10篇指南
1指南评论
My product is On Stage I. It's too old. The screw fixing posts protruding from the plastic casing have broken on their own. As a result, the upper and lower shells cannot be completely sealed. When music is played, sound waves leak out of the gaps. It sounds thin and has no depth. It's like placing four speaker units directly outside the enclosure. Bass cannot resonate inside the enclosure, but travels through the bass hole in the middle. I really like this speaker. There's no way I'm giving it up. Is there any way to solve this? Should I look for a used case or use an existing case to rebuild the screw mounting posts? What should I do if I choose to rebuild?
怪醫杜立德 - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 234
