跳转到主内容
Cracked Grout Replacement
你所需要的
  1. Cracked Grout Replacement, Cracked Grout: 步骤 1 中的图像 1,2 Cracked Grout Replacement, Cracked Grout: 步骤 1 中的图像 2,2
    • Identify the crack you will be repairing.
    • Surround it with Painters Tape.
  2. Cracked Grout Replacement: 步骤 2 中的图像 1,1
    • Wear protective eye wear and a mask to shield yourself from dust and debris.
    • Use caution when handling the concrete grinder. If handled improperly it can lead to an injury.
    • Use the concrete grinder to remove the grout surrounded with tape where the crack is located.
  3. Cracked Grout Replacement: 步骤 3 中的图像 1,2 Cracked Grout Replacement: 步骤 3 中的图像 2,2
    • Go in with your handheld grout remover and scrape out the remaining grout between the tile until it is completely hollow.
  4. Cracked Grout Replacement: 步骤 4 中的图像 1,2 Cracked Grout Replacement: 步骤 4 中的图像 2,2
    • Vacuum the dust and grout that was removed to reveal a clean and hollow space.
  5. Cracked Grout Replacement: 步骤 5 中的图像 1,1
    • Color match your grout by using grout samples to get your desired color of grout.
  6. Cracked Grout Replacement: 步骤 6 中的图像 1,3 Cracked Grout Replacement: 步骤 6 中的图像 2,3 Cracked Grout Replacement: 步骤 6 中的图像 3,3
    • Mix a scoop of grout and sealer to create a paste.
  7. Cracked Grout Replacement: 步骤 7 中的图像 1,3 Cracked Grout Replacement: 步骤 7 中的图像 2,3 Cracked Grout Replacement: 步骤 7 中的图像 3,3
    • Take the rubber grout float and press the grout paste securely into the crack.
  8. Cracked Grout Replacement: 步骤 8 中的图像 1,2 Cracked Grout Replacement: 步骤 8 中的图像 2,2
    • Take the grouting sponge and smooth out the grout evenly.
    • Let the grout sit and harden for twenty-four hours.
  9. Cracked Grout Replacement: 步骤 9 中的图像 1,1
    • Your new grout is dry and ready for use.
结论
To repair any other cracks in grout, repeat these steps.
7等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 33
过去 30 天: 189
总计 3,652
