跳转到主内容
Cowon iAudio U2 Microphone Replacement
你所需要的
  1. Cowon iAudio U2 Microphone Replacement, Microphone: 步骤 1 中的图像 1,1
    • Before starting the disassemble, make sure the device is powered off.
    • Unscrew the 4 screws using the PH000 drill bit from the iFixit toolkit.
    • Don't forget to place the screws aside in a safe location, perhaps use a magnetic board to store them. You will need the screws to put the device back together.
  2. Cowon iAudio U2 Microphone Replacement: 步骤 2 中的图像 1,2 Cowon iAudio U2 Microphone Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool from the iFixit toolkit to separate the back from the front of the device. This can be done by wedging the opening tool in the crack where the two sides of the device cover meet.
    • After it is wedged in push down on the exposed end until the two sides come apart.
  3. Cowon iAudio U2 Microphone Replacement: 步骤 3 中的图像 1,3 Cowon iAudio U2 Microphone Replacement: 步骤 3 中的图像 2,3 Cowon iAudio U2 Microphone Replacement: 步骤 3 中的图像 3,3
    • In order to get to the wires of the microphone you will need to peel back the battery.
    • You will need to pull out both of the wires of the microphone connected to the motherboard in order to replace the microphone.
  4. Cowon iAudio U2 Microphone Replacement: 步骤 4 中的图像 1,2 Cowon iAudio U2 Microphone Replacement: 步骤 4 中的图像 2,2
    • Next, you will need to take the new microphone and solder it to the motherboard using a soldering iron.
    • Note when using the soldering tool that the sliver bar may become too hot, so that is a part of the tool to avoid touching while in use.
结论
3等其他人完成本指南。
Justin Proshka
于01/14/16注册
624 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 276
