跳转到主内容
Cowon iAudio U2 Headphone Jack Replacement
你所需要的
  1. Cowon iAudio U2 Headphone Jack Replacement, Headphone Jack: 步骤 1 中的图像 1,1
    • Before starting the disassembly, make sure the device is powered off.
    • Unscrew the 4 screws using the PH000 drill bit from the iFixit toolkit.
    • Don't forget to store the screws in a safe location, such as a magnetic board. You will need the screws to put the device back together later.
  2. Cowon iAudio U2 Headphone Jack Replacement: 步骤 2 中的图像 1,2 Cowon iAudio U2 Headphone Jack Replacement: 步骤 2 中的图像 2,2
    • Use the plastic opening tool from the iFixit toolkit to separate the back from the front of the device. To do this, wedge the opening tool into the crack where the two sides of the device cover meet.
    • After the tool is wedged in, push down on the exposed end until the two sides come apart.
  3. Cowon iAudio U2 Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • Using the PH000 drill bit from the iFixit toolkit, unscrew the 2 screws that attach the motherboard to the device.
  4. Cowon iAudio U2 Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Using the plastic opening tool from the iFixit toolkit, insert the tool in between the device and the motherboard. Push down on the exposed end of the device to release the motherboard from the device.
  5. Cowon iAudio U2 Headphone Jack Replacement: 步骤 5 中的图像 1,2 Cowon iAudio U2 Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Using the soldering tool, remove the headphone jack from the device.
    • Be careful when using the soldering device as it will be very hot.
    • Using the soldering tool, replace the old headphone jack with a new one. Solder the new headphone jack into place.
结论
Justin Proshka
于01/14/16注册
624 声望
创作了5篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 437
