跳转到主内容
Cowin E7 Ear Cushion Replacement
你所需要的
  1. Cowin E7 Ear Cushion Replacement, Ear Cushion: 步骤 1 中的图像 1,1
    • Inspect the seal around the edge of each ear cushion for damage or instability.
    • Make note of which ear cushion needs to be replaced.
  2. Cowin E7 Ear Cushion Replacement: 步骤 2 中的图像 1,1
    • Firmly grasp the ear cushion on one side and pull up.
    • The ear cushion is only attached by a few spots of glue, so it should not take much force to remove.
  3. Cowin E7 Ear Cushion Replacement: 步骤 3 中的图像 1,1
    • Spread multipurpose glue around the edge of the seal.
    • Keep in mind that the more glue you use, the harder it will be to remove the ear cushions again.
    • Place the replacement ear cushions where the damaged cushions were.
    • Hold for at least thirty seconds to ensure the glue has time to dry and seal the new cushions to the headphones.
终点
4等其他人完成本指南。
Jacob Burrer
于03/26/22注册
439 声望
创作了2篇指南
团队
UMass Dartmouth, Team 2-2, Mellen Spring 2022 UMass Dartmouth, Team 2-2, Mellen Spring 2022 的会员
UMASSD-MELLEN-S22S2G2
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 30
过去 30 天: 158
总计 4,529
