跳转到主内容
Corsair Void Pro RGB Speakers Replacement
你所需要的
  1. Corsair Void Pro RGB Speakers Replacement, Earcup: 步骤 1 中的图像 1,1
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Speakers Replacement: 步骤 2 中的图像 1,2 Corsair Void Pro RGB Speakers Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Speakers Replacement: 步骤 3 中的图像 1,2 Corsair Void Pro RGB Speakers Replacement: 步骤 3 中的图像 2,2
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
  4. Corsair Void Pro RGB Speakers Replacement, Speakers: 步骤 4 中的图像 1,1
    • Desolder the wire that connects to the speaker.
    • For steps on how to solder, see this helpful guide.
  5. Corsair Void Pro RGB Speakers Replacement: 步骤 5 中的图像 1,2 Corsair Void Pro RGB Speakers Replacement: 步骤 5 中的图像 2,2
    • Use a knife tool as a wedge to remove the speaker and glue in the new speaker.
结论
4等其他人完成本指南。
Gianna Nobili
于04/15/19注册
827 声望
创作了5篇指南
团队
Cal Poly, Team S9-G13, Maness Spring 2019 Cal Poly, Team S9-G13, Maness Spring 2019 的会员
CPSU-MANESS-S19S9G13
4 名成员
创作了14篇指南
5条评论
Where can i find a new speaker ?
brunodehulster - 回复
The speaker listed in the parts, is not the correct speaker. I purchased them and they are NOT a fit.
ksmith - 回复
Whats the size of the speaker?
smack2k - 回复
The size of the speaker is 50 mm and about 10 mm in depth. I used this speaker in my own repair and it worked well.
noahoryan -
Can u show how to change “Charging Port”??
Jason HKB - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 33
总计 3,480
