跳转到主内容
Corsair Void Pro RGB Lights Replacement
你所需要的
  1. Corsair Void Pro RGB Lights Replacement, Earcup: 步骤 1 中的图像 1,1
    • Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
  2. Corsair Void Pro RGB Lights Replacement: 步骤 2 中的图像 1,2 Corsair Void Pro RGB Lights Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
    • If you are disassembling the lefthand earfmuff, there will be eight 6.4 mm screws to remove.
  3. Corsair Void Pro RGB Lights Replacement: 步骤 3 中的图像 1,2 Corsair Void Pro RGB Lights Replacement: 步骤 3 中的图像 2,2
    • Remove and set aside the black panel, taking care to keep the wires attached.
    • The panel should lift up without much force. If the panel does not budge, carefully use the iFixit plastic opening tool to dislodge the piece.
  4. Corsair Void Pro RGB Lights Replacement, Battery: 步骤 4 中的图像 1,2 Corsair Void Pro RGB Lights Replacement, Battery: 步骤 4 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the three 6.4 mm screws on the black plastic panel with the grid of holes.
  5. Corsair Void Pro RGB Lights Replacement: 步骤 5 中的图像 1,2 Corsair Void Pro RGB Lights Replacement: 步骤 5 中的图像 2,2
    • Carefully unplug the wire that connects the battery pack to the headphones.
    • This should not take too much force.
  6. Corsair Void Pro RGB Lights Replacement: 步骤 6 中的图像 1,1
    • Remove the clear plastic covering and set aside.
  7. Corsair Void Pro RGB Lights Replacement, Lights: 步骤 7 中的图像 1,2 Corsair Void Pro RGB Lights Replacement, Lights: 步骤 7 中的图像 2,2
    • There is a small circuit board near the bottom of the muff.
    • Using a Phillips #0 screwdriver, unscrew the single screw holding the circuit board in place.
  8. Corsair Void Pro RGB Lights Replacement: 步骤 8 中的图像 1,1
    • Remove the circuit board from its plastic slot.
    • If this is the first time the lights have been removed from the headphones, you may need to wiggle the circuit board out of place or use plastic tweezers to loosen it from the manufacturer's adhesive.
  9. Corsair Void Pro RGB Lights Replacement: 步骤 9 中的图像 1,1
    • Desolder the three points where the wires connect to the circuit board. For detailed instructions on soldering, see this helpful guide.
    • Take note of where each of the wires goes to simplify the resoldering process.
    • Follow these steps again to replace the light on the other earcup.
结论
2等其他人完成本指南。
Gianna Nobili
于04/15/19注册
827 声望
创作了5篇指南
团队
Cal Poly, Team S9-G13, Maness Spring 2019 Cal Poly, Team S9-G13, Maness Spring 2019 的会员
CPSU-MANESS-S19S9G13
4 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 13
总计 1,299
