跳转到主内容
Corsair M55 RGB Pro Gaming Mouse Motherboard
你所需要的
  1. Corsair M55 RGB Pro Gaming Mouse Motherboard, Motherboard: 步骤 1 中的图像 1,3 Corsair M55 RGB Pro Gaming Mouse Motherboard, Motherboard: 步骤 1 中的图像 2,3 Corsair M55 RGB Pro Gaming Mouse Motherboard, Motherboard: 步骤 1 中的图像 3,3
    • Use a spudger to gently peel off and remove the three mouse feet on the bottom of the mouse.
    • If you are not replacing the mouse feet with a new set, put them aside to replace them at the end of the repair.
  2. Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 2 中的图像 1,3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 2 中的图像 2,3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the four 10 mm screws from the bottom of the mouse.
    • There is a cable connecting the bottom and top of the mouse.
  3. Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 3 中的图像 1,2 Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 3 中的图像 2,2
    • Use a spudger to separate the top and bottom of the mouse.
    • Don't pull them apart as they are connected by a cable connector and could become damaged.
    • Pull the PCB cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
  4. Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 4 中的图像 1,2 Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 4 中的图像 2,2
    • Pull the USB pin cable away from the connector in the same direction as the individual wires are running.
  5. Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 5 中的图像 1,3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 5 中的图像 2,3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 5 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws that secure the motherboard.
  6. Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 6 中的图像 1,3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 6 中的图像 2,3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 6 中的图像 3,3
    • Carefully lift the motherboard out of the base of the mouse by the edges.
  7. Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 7 中的图像 1,3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 7 中的图像 2,3 Corsair M55 RGB Pro Gaming Mouse Motherboard: 步骤 7 中的图像 3,3
    • If necessary, remove the mouse wheel by sliding it to the right.
    • It should come out of the slot easily as it's not attached.
结论
Rizza Barnwell
于03/05/24注册
145 声望
撰写一个指南
团队
CSU Los Angeles, Team 8-11, Grodsky Spring 2024 CSU Los Angeles, Team 8-11, Grodsky Spring 2024 的会员
CSULA-GRODSKY-S24S8G11
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 14
过去 30 天: 24
总计 62
