跳转到主内容
Corsair Katar Scroll Wheel Sensor
你所需要的
  1. Corsair Katar Scroll Wheel Sensor, Corsair Katar Disassembly: 步骤 1 中的图像 1,2 Corsair Katar Scroll Wheel Sensor, Corsair Katar Disassembly: 步骤 1 中的图像 2,2
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar Scroll Wheel Sensor: 步骤 2 中的图像 1,1
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar Scroll Wheel Sensor: 步骤 3 中的图像 1,2 Corsair Katar Scroll Wheel Sensor: 步骤 3 中的图像 2,2
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar Scroll Wheel Sensor: 步骤 4 中的图像 1,1
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
  5. Corsair Katar Scroll Wheel Sensor, Scroll Wheel: 步骤 5 中的图像 1,2 Corsair Katar Scroll Wheel Sensor, Scroll Wheel: 步骤 5 中的图像 2,2
    • Use the JIS 0 screwdriver to remove the two 5mm screws on the motherboard.
  6. Corsair Katar Scroll Wheel Sensor: 步骤 6 中的图像 1,1
    • Use the plastic opening tool to pry the white cable jack away from the motherboard.
    • Lift the motherboard away from the bottom of the mouse.
  7. Corsair Katar Scroll Wheel Sensor: 步骤 7 中的图像 1,1
    • Push the scroll wheel to the right side of the motherboard as shown, then pull it away from the board to remove.
  8. Corsair Katar Scroll Wheel Sensor, Scroll Wheel Sensor: 步骤 8 中的图像 1,2 Corsair Katar Scroll Wheel Sensor, Scroll Wheel Sensor: 步骤 8 中的图像 2,2
    • Flip the motherboard over and remove the clear plastic cover from the bottom of the board.
  9. Corsair Katar Scroll Wheel Sensor: 步骤 9 中的图像 1,2 Corsair Katar Scroll Wheel Sensor: 步骤 9 中的图像 2,2
    • Desolder the 5 connecting pins to remove the scroll wheel sensor from the motherboard.
结论
2等其他人完成本指南。
团队
UW Tacoma, Team S1-G3, Cardinal Summer 2018 UW Tacoma, Team S1-G3, Cardinal Summer 2018 的会员
UWT-CARDINAL-SU18S1G3
3 名成员
创作了12篇指南
2条评论
bonsoir moi ma molette tourne dans le vide rien ne accroche merci
Tara - 回复
Do I need new pads when I take out the old ones or will the same one stick?
Ishaan Patel - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 14
过去 30 天: 24
总计 1,514
