跳转到主内容
Corsair Katar Disassembly
你所需要的
  1. Corsair Katar Disassembly, Corsair Katar Disassembly: 步骤 1 中的图像 1,2 Corsair Katar Disassembly, Corsair Katar Disassembly: 步骤 1 中的图像 2,2
    • Unplug your mouse before starting.
    • Flip the mouse over so the bottom is facing up.
  2. Corsair Katar Disassembly: 步骤 2 中的图像 1,1
    • Remove the three skates on the bottom of the mouse using the plastic opening tools.
    • Skates will be very sticky.
  3. Corsair Katar Disassembly: 步骤 3 中的图像 1,2 Corsair Katar Disassembly: 步骤 3 中的图像 2,2
    • Use the JIS 0 screwdriver to remove the four 5 mm screws on the bottom of the mouse.
  4. Corsair Katar Disassembly: 步骤 4 中的图像 1,1
    • Detach the bottom of the mouse from the upper shell.
    • Remove the shell slowly so as not to damage the white DPI cable inside the mouse.
    • Use the plastic opening tool to detach the white DPI sensor cable from its port.
    • Alternatively, you can use your hand to remove the DPI sensor cable by wiggling it out of the port.
结论
3等其他人完成本指南。
Ryan Matesa
于07/12/18注册
248 声望
撰写一个指南
团队
UW Tacoma, Team S1-G3, Cardinal Summer 2018 UW Tacoma, Team S1-G3, Cardinal Summer 2018 的会员
UWT-CARDINAL-SU18S1G3
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 50
总计 2,649
