跳转到主内容
Cordoba C5 Classical Guitar String Replacement
你所需要的
  1. Cordoba C5 Classical Guitar String Replacement, String: 步骤 1 中的图像 1,2 Cordoba C5 Classical Guitar String Replacement, String: 步骤 1 中的图像 2,2
    • Loosen the guitar string by turning the tuning peg in a counterclockwise direction.
    • The string should be completely loose.
  2. Cordoba C5 Classical Guitar String Replacement: 步骤 2 中的图像 1,3 Cordoba C5 Classical Guitar String Replacement: 步骤 2 中的图像 2,3 Cordoba C5 Classical Guitar String Replacement: 步骤 2 中的图像 3,3
    • Remove the old string from the bridge by undoing the knot and pulling it out from the bridge hole.
  3. Cordoba C5 Classical Guitar String Replacement: 步骤 3 中的图像 1,3 Cordoba C5 Classical Guitar String Replacement: 步骤 3 中的图像 2,3 Cordoba C5 Classical Guitar String Replacement: 步骤 3 中的图像 3,3
    • Remove the other end of the old string from the headstock by undoing the knot on the barrel and pulling it out of the barrel hole.
  4. Cordoba C5 Classical Guitar String Replacement: 步骤 4 中的图像 1,3 Cordoba C5 Classical Guitar String Replacement: 步骤 4 中的图像 2,3 Cordoba C5 Classical Guitar String Replacement: 步骤 4 中的图像 3,3
    • Take your new nylon guitar string and feed one end into the bridge hole.
    • Leave enough string at the base of the body to tie a knot.
    • To tie the knot, hold onto the longer end of the string with your left hand and grab the end of the short string with your right hand. Wrap the end of the short string back around itself two times. The string should resemble a figure-8 pattern.
    • Hold down the knot on the bridge with your fingers and pull the longer end of the string with your left hand to tighten the knot.
  5. Cordoba C5 Classical Guitar String Replacement: 步骤 5 中的图像 1,3 Cordoba C5 Classical Guitar String Replacement: 步骤 5 中的图像 2,3 Cordoba C5 Classical Guitar String Replacement: 步骤 5 中的图像 3,3
    • Feed the other end of the string over the barrel hole. Bring the string over the barrel again and feed it into the barrel hole.
    • This will create a loop that secures the string on the barrel.
  6. Cordoba C5 Classical Guitar String Replacement: 步骤 6 中的图像 1,3 Cordoba C5 Classical Guitar String Replacement: 步骤 6 中的图像 2,3 Cordoba C5 Classical Guitar String Replacement: 步骤 6 中的图像 3,3
    • With your right hand, keep the string tense so that the knot at the bridge does not come undone.
    • Turn the tuning peg clockwise to tighten the string.
  7. Cordoba C5 Classical Guitar String Replacement: 步骤 7 中的图像 1,3 Cordoba C5 Classical Guitar String Replacement: 步骤 7 中的图像 2,3 Cordoba C5 Classical Guitar String Replacement: 步骤 7 中的图像 3,3
    • Check the bridge and headstock to ensure the string is secure.
    • If you have excess string at the headstock, trim it with cutting pliers for a neater look.
终点
Joana Jimenez
于02/20/24注册
145 声望
撰写一个指南
团队
CSU Sacramento, Team 1-7, Laflen Spring 2024 CSU Sacramento, Team 1-7, Laflen Spring 2024 的会员
CSUSAC-LAFLEN-S24S1G7
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 204
