跳转到主内容
Coolpix S01 Zoom Trigger Replacement
你所需要的
  1. Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: 步骤 1 中的图像 1,3 Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: 步骤 1 中的图像 2,3 Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: 步骤 1 中的图像 3,3
    • Before starting, make sure the camera is powered off.
    • Take the Hex and PH000 bit to remove a 2mm screw from the left side of the camera.
    • Next, remove the 2mm screw from the right side.
    • Lastly, remove the 3mm screw from the bottom of the camera.
  2. Coolpix S01 Zoom Trigger Replacement: 步骤 2 中的图像 1,3 Coolpix S01 Zoom Trigger Replacement: 步骤 2 中的图像 2,3 Coolpix S01 Zoom Trigger Replacement: 步骤 2 中的图像 3,3
    • Once the two 2mm screws and the 3 mm screw have been removed, use the smallest plastic opening tool and pull up on the sides to reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Zoom Trigger Replacement: 步骤 3 中的图像 1,2 Coolpix S01 Zoom Trigger Replacement: 步骤 3 中的图像 2,2
    • After the battery is out, remove the gray button bar from the top of the camera with the smallest opening tool.
    • With the gray bar detached from the camera, turn it upside down. With the Hex and the J000 bit remove the two 1mm screws.
  4. Coolpix S01 Zoom Trigger Replacement: 步骤 4 中的图像 1,2 Coolpix S01 Zoom Trigger Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Take the needle nose tweezers to remove the black ring in the middle of the button.
    • You have successfully removed the zoom trigger and can replace with a new one if needed.
    • To reassemble follow steps in reverse.
结论
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 327
