跳转到主内容
Coolpix S01 Screen Cover Replacement
你所需要的
  1. Coolpix S01 Screen Cover Replacement, Screen Cover: 步骤 1 中的图像 1,3 Coolpix S01 Screen Cover Replacement, Screen Cover: 步骤 1 中的图像 2,3 Coolpix S01 Screen Cover Replacement, Screen Cover: 步骤 1 中的图像 3,3
    • First make sure the camera is powered off.
    • Use the Hex and PH000 tool to remove the 2 mm screw from the left side of the camera.
  2. Coolpix S01 Screen Cover Replacement: 步骤 2 中的图像 1,3 Coolpix S01 Screen Cover Replacement: 步骤 2 中的图像 2,3 Coolpix S01 Screen Cover Replacement: 步骤 2 中的图像 3,3
    • Next, remove the 2 mm screw from the right side of the camera
    • Remove the 3mm screw from the bottom of the camera.
    • Once you have the 2mm and 3mm screws out, gently pull the sides up with the smallest plastic opening tool. This will reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Screen Cover Replacement: 步骤 3 中的图像 1,3 Coolpix S01 Screen Cover Replacement: 步骤 3 中的图像 2,3 Coolpix S01 Screen Cover Replacement: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • With the screen facing outward, locate the orange ribbon cable from the motherboard.
    • With the straight tweezers, gently pull out the orange ribbon cable from the motherboard.
  4. Coolpix S01 Screen Cover Replacement: 步骤 4 中的图像 1,3 Coolpix S01 Screen Cover Replacement: 步骤 4 中的图像 2,3 Coolpix S01 Screen Cover Replacement: 步骤 4 中的图像 3,3
    • With the lens facing down and the bottom of the camera facing away from you, lift up the right edge of the LCD screen.
    • Use the plastic tool to gently lift the screen out from the upper left corner until the seal is broken.
结论
另外一个人完成了本指南。
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 454
