跳转到主内容
Coolpix S01 Battery Replacement
你所需要的
  1. Coolpix S01 Battery Replacement, Battery: 步骤 1 中的图像 1,3 Coolpix S01 Battery Replacement, Battery: 步骤 1 中的图像 2,3 Coolpix S01 Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Before starting, make sure the camera is powered off.
    • Take the Hex and PH000 bit to remove a 2mm screw from the left side of the camera.
    • Next, remove the 2mm screw from the right side.
    • Lastly, remove the 3mm screw from the bottom of the camera.
  2. Coolpix S01 Battery Replacement: 步骤 2 中的图像 1,3 Coolpix S01 Battery Replacement: 步骤 2 中的图像 2,3 Coolpix S01 Battery Replacement: 步骤 2 中的图像 3,3
    • Once the two 2mm screws and the 3 mm screw have been removed, use the smallest plastic opening tool and pull up on the sides to reveal the inside of the camera.
    • Next, use the same small plastic opening tool and gently pull out the battery.
    • To reassemble, follow the steps in reverse order.
结论
3等其他人完成本指南。
Becca Hall
于10/13/15注册
173 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 57
总计 3,167
