简介
The Coolpad Rogue’s battery is very easy to replace, and this procedure can be used for a variety of ways involving the battery.
While holding onto the phone with your other hand, insert a clean fingernail into the USB port and pull up on it until the cover pops out of place.
While still holding onto the phone with your other hand, pull up on the loosened cover until it pops out.
Place a fingernail in the notch at the bottom of the battery. Lift the bottom of the battery up, then remove it.
To reassemble your device, follow these instructions in reverse order. Make sure to press firmly around the back cover when reinstalling it to ensure it is securely in place
另外一个人完成了本指南。
