跳转到主内容
Coolpad Defiant Rear Camera Replacement
你所需要的
  1. Coolpad Defiant Rear Camera Replacement, Back Cover: 步骤 1 中的图像 1,2 Coolpad Defiant Rear Camera Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Rear Camera Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover from your device.
  3. Coolpad Defiant Rear Camera Replacement, Battery: 步骤 3 中的图像 1,1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Rear Camera Replacement, Rear Camera: 步骤 4 中的图像 1,1
    • Using a Phillips #000 screwdriver, remove the screws holding the rear mid-frame cover to the mid-frame assembly.
  5. Coolpad Defiant Rear Camera Replacement: 步骤 5 中的图像 1,2 Coolpad Defiant Rear Camera Replacement: 步骤 5 中的图像 2,2
    • Using either a plastic pry tool or your hands, pry the plastic cover away.
  6. Coolpad Defiant Rear Camera Replacement: 步骤 6 中的图像 1,1
    • Using the Phillips #000 screwdriver, remove the three screws holding the top logic board to the main frame.
  7. Coolpad Defiant Rear Camera Replacement: 步骤 7 中的图像 1,3 Coolpad Defiant Rear Camera Replacement: 步骤 7 中的图像 2,3 Coolpad Defiant Rear Camera Replacement: 步骤 7 中的图像 3,3
    • Using the plastic pry tool, remove the flex cables for the screen, side buttons, and digitizer.
    • Using the same tool, remove the antenna from the bottom logic board
  8. Coolpad Defiant Rear Camera Replacement: 步骤 8 中的图像 1,3 Coolpad Defiant Rear Camera Replacement: 步骤 8 中的图像 2,3 Coolpad Defiant Rear Camera Replacement: 步骤 8 中的图像 3,3
    • Carefully pull up on the upper logic board starting from the top and pull it straight up.
    • Once the logic board is lifted perpendicular to the mid-frame, remove the flex cable on the bottom left side of the board.
  9. Coolpad Defiant Rear Camera Replacement: 步骤 9 中的图像 1,1
    • Flipping the logic board upside down, use the plastic pry tool to disconnect the flex cable connecting the camera to the logic board.
    • Pull straight up on the camera and it will slide out of the logic board.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 256
