跳转到主内容
Coolpad Defiant Daughterboard Replacement
你所需要的
  1. Coolpad Defiant Daughterboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Coolpad Defiant Daughterboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Daughterboard Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover from your device.
  3. Coolpad Defiant Daughterboard Replacement, Battery: 步骤 3 中的图像 1,1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
  4. Coolpad Defiant Daughterboard Replacement, Daughterboard: 步骤 4 中的图像 1,2 Coolpad Defiant Daughterboard Replacement, Daughterboard: 步骤 4 中的图像 2,2
    • Remove all fifteen screws using the Phillips #000 screwdriver.
    • Remove the back panel after all screws are removed.
  5. Coolpad Defiant Daughterboard Replacement: 步骤 5 中的图像 1,3 Coolpad Defiant Daughterboard Replacement: 步骤 5 中的图像 2,3 Coolpad Defiant Daughterboard Replacement: 步骤 5 中的图像 3,3
    • Disconnect the metal cable using the plastic spudger.
    • The remove the glued down speaker from the backing.
    • Disconnect the little black wire from lower logic board.
  6. Coolpad Defiant Daughterboard Replacement: 步骤 6 中的图像 1,1
    • Using the plastic spudger remove the lower logic board because the only thing that is holding it down is glue.
结论
Elijah Gastin
于09/21/18注册
100 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 10
总计 460
