跳转到主内容
Coolpad Defiant Battery Replacement
你所需要的
  1. Coolpad Defiant Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 Coolpad Defiant Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Turn the phone with the back cover facing towards you.
    • Carefully remove the back cover by holding one corner of the case and carefully pulling it away from the phone.
    • The plastic case and inner components can break if not pulled carefully, so pull cautiously.
  2. Coolpad Defiant Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover from your device.
  3. Coolpad Defiant Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Find the gap on the bottom of the battery.
    • With a tool or with your hands, pull the battery upward and set it aside safely.
    • Remember to return the battery once you are done, safely placing it in the correct position or as how you first saw it.
    • Be careful with old or damaged batteries and dispose of it appropriately
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 1,452
