跳转到主内容
Coolpad 3300A Disassembly
你所需要的
  1. Coolpad 3300A Disassembly, Coolpad 3300A Disassembly: 步骤 1 中的图像 1,1
    • After removing the back of the phone (not pictured), remove the battery by lifting up from the bottom with your thumb. There will be a groove that allows you to remove the battery with your thumb.
  2. Coolpad 3300A Disassembly: 步骤 2 中的图像 1,3 Coolpad 3300A Disassembly: 步骤 2 中的图像 2,3 Coolpad 3300A Disassembly: 步骤 2 中的图像 3,3
    • Remove the four screws (30 mm long) which hold the front and back half of the unit together using a Phillips #000 screwdriver. There will be one screw in each corner.
  3. Coolpad 3300A Disassembly: 步骤 3 中的图像 1,3 Coolpad 3300A Disassembly: 步骤 3 中的图像 2,3 Coolpad 3300A Disassembly: 步骤 3 中的图像 3,3
    • Use a metal spudger to release all of the clips around the phone. These clips are used to hold the front and back panel on the phone together.
  4. Coolpad 3300A Disassembly: 步骤 4 中的图像 1,1
    • After the clips are released, carefully separate the back housing from the phone. Notice the sticker that appears in the red box holds the phone together, but can be peeled apart.
结论
6等其他人完成本指南。
Riley Casteel
于03/26/18注册
395 声望
撰写一个指南
团队
IUPUI, Team S1-G3, Harley Spring 2018 IUPUI, Team S1-G3, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S1G3
6 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 9
总计 1,060
