跳转到主内容
Cooler Master Laptop Fan Replacement
你所需要的
  1. Cooler Master Laptop Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Set your laptop cooler on the table and make sure it is not plugged into a laptop or powered on.
    • Never try to open the cooler while plugged in.
  2. Cooler Master Laptop Fan Replacement: 步骤 2 中的图像 1,1
    • Flip the Device over and find ten folded metal slots holding the metal cover onto the base.
  3. Cooler Master Laptop Fan Replacement: 步骤 3 中的图像 1,3 Cooler Master Laptop Fan Replacement: 步骤 3 中的图像 2,3 Cooler Master Laptop Fan Replacement: 步骤 3 中的图像 3,3
    • Bend each metal flap straight up with the pliers to allow the metal cover to slide off.
  4. Cooler Master Laptop Fan Replacement: 步骤 4 中的图像 1,2 Cooler Master Laptop Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the cover and expose the inside of the Cooler.
  5. Cooler Master Laptop Fan Replacement: 步骤 5 中的图像 1,2 Cooler Master Laptop Fan Replacement: 步骤 5 中的图像 2,2
    • Unplug the power cable to the fan.
    • Make sure not to apply too much force and disconnect the wires to the device.
  6. Cooler Master Laptop Fan Replacement: 步骤 6 中的图像 1,2 Cooler Master Laptop Fan Replacement: 步骤 6 中的图像 2,2
    • On the bottom of the base locate the screw holes under the sticker on the base.
    • Unscrew the three fan screws.
  7. Cooler Master Laptop Fan Replacement: 步骤 7 中的图像 1,1
    • Once all the pieces are taken apart, set aside the old fan and prep the new one for installation.
  8. Cooler Master Laptop Fan Replacement: 步骤 8 中的图像 1,1
    • Apply a small amount of thermal compound to the base where the fan sets.
    • Make sure to apply thermal compound to keep the fan from overheating and damaging the base.
  9. Cooler Master Laptop Fan Replacement: 步骤 9 中的图像 1,2 Cooler Master Laptop Fan Replacement: 步骤 9 中的图像 2,2
    • Connect power cable for the fan and place the cables back in their slots.
  10. Cooler Master Laptop Fan Replacement: 步骤 10 中的图像 1,2 Cooler Master Laptop Fan Replacement: 步骤 10 中的图像 2,2
    • Screw fan back onto base.
  11. Cooler Master Laptop Fan Replacement: 步骤 11 中的图像 1,1
    • Place cover back on base.
  12. Cooler Master Laptop Fan Replacement: 步骤 12 中的图像 1,1
    • Fold all metal flaps back to hold cover on base.
  13. Cooler Master Laptop Fan Replacement: 步骤 13 中的图像 1,1
    • Flip it over and it's finished.
结论
Plug in the USB to insure proper working condition. And the cooling pad fan replacement is done.
2等其他人完成本指南。
2条评论
Hi there,
I’ve got a Targus Lap Chill Matt (Laptop Cooling Pad 15 - 17" Laptops) but the USB port had worn out and require a new replacement. Does anyone have any examples on how to replace the UBS port from a Laptop Cooler Pad?
Thanks!
rolly - 回复
Hi,
Just wanted to say huge thanks to you for this guideline! I have a Cooler Master Notepal L1 and the fan kept making noises. But now it works totally fine after I was able to open the cover.
Thanks again!
//Parisa
Parisa - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 101
总计 5,703
