简介
If your Zenbre SoundBank Z3 speaker isn't working properly and is not responding to your touch, then there is most likely an issue with the internal circuit board that connects the buttons to the motherboard. The motherboard is custom to the device, so you will need to get a replacement from a similar device in order to repair your speaker.
你所需要的
Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
Remove the plastic panel.
Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
Remove the two 4.5 mm Phillips silver screws holding down the motherboard.
Lift the motherboard out of its housing.
另外一个人完成了本指南。
