跳转到主内容
Connecting to WiFi with your Kindle Fire HDX 7"
  1. Connecting to WiFi with your Kindle Fire HDX 7", Opening the Quick Settings Menu: 步骤 1 中的图像 1,1
    • Turn your device on and wait for the home screen to load.
    • Once you are at the home screen, use your finger and swipe down from the top of the LCD Screen to bring up the Quick Settings menu.
  2. Connecting to WiFi with your Kindle Fire HDX 7", Adding a wireless network: 步骤 2 中的图像 1,1
    • While in the Quick Settings menu, tap "Wireless".
    • Please note that your device will not connect to a WiFi network if your device is in "Airplane Mode", make sure Airplane Mode is set to Off.
  3. Connecting to WiFi with your Kindle Fire HDX 7": 步骤 3 中的图像 1,1
    • Tap the "WiFi" button, which will bring up a list of networks that are in range.
    • Tap a WiFi network, then press "Connect" in order to connect to it.
    • If you see a lock on the network, you may need a password in order for you to gain access to the network. Enter the password then press "Connect".
    • If you don't know the password for the network you are trying to connect to, try contacting the person who set up the network.
结论
2等其他人完成本指南。
Connor Michienzie
于10/16/14注册
161 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-2, Duarte Fall 2014 UMass Dartmouth, Team 1-2, Duarte Fall 2014 的会员
UMASSD-DUARTE-F14S1G2
4 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 517
