跳转到主内容
Connect Four Electronic Handheld Speaker Replacement
你所需要的
  1. Connect Four Electronic Handheld Speaker Replacement, Ensure the device is off.: 步骤 1 中的图像 1,1
    • Make sure the Connect Four Electronic Handheld is off by allowing it to shut off automatically.
  2. Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: 步骤 2 中的图像 1,2 Connect Four Electronic Handheld Speaker Replacement, Removing the battery casing.: 步骤 2 中的图像 2,2
    • Using a Phillips head screwdriver, remove the (9.1mm length) #2 screw in the middle of the battery casing.
    • Slide the cover off and remove the battery.
  3. Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: 步骤 3 中的图像 1,2 Connect Four Electronic Handheld Speaker Replacement, Removing/Replacing the Back Casing: 步骤 3 中的图像 2,2
    • Using a Phillips head screwdriver, remove the four (7.1mm- length) #3 screws that hold the back casing in place.
    • Carefully remove the back casing.
    • When removing the back casing, make sure not to rupture the wires that connect the speaker to the circuit board.
  4. Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: 步骤 4 中的图像 1,3 Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: 步骤 4 中的图像 2,3 Connect Four Electronic Handheld Speaker Replacement, Replacing the speaker: 步骤 4 中的图像 3,3
    • If the speaker is in working condition, but the wires are broken or disconnected, skip this step and move on to step 5.
    • Locate the speaker on the back casing.
    • Using a spudger, wedge the speaker out of its place until it slides out.
    • Take the replacement speaker and wedge it back into its space.
  5. Connect Four Electronic Handheld Speaker Replacement, Re-Soldering the Speaker Wire: 步骤 5 中的图像 1,1
    • Using a soldering iron, solder both red wires to their appropriate connections.
    • Be extremely careful when using a soldering iron! Contact with the tip could cause severe burns.
结论
另外一个人完成了本指南。
Wil
于10/22/14注册
313 声望
创作了3篇指南
团队
Baylor, Team 8-11, Williams Fall 2014 Baylor, Team 8-11, Williams Fall 2014 的会员
BU-WILLIAMS-F14S8G11
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 215
