跳转到主内容
Condenser Microphone Shock Mount Cord Replacement
  1. Condenser Microphone Shock Mount Cord Replacement, Cords: 步骤 1 中的图像 1,2 Condenser Microphone Shock Mount Cord Replacement, Cords: 步骤 1 中的图像 2,2
    • Begin by removing the top broken cord from the mic holder.
    • Be gentle with the removal of the cords. Forceful removal could result in damaging the mic holder itself.
  2. Condenser Microphone Shock Mount Cord Replacement: 步骤 2 中的图像 1,3 Condenser Microphone Shock Mount Cord Replacement: 步骤 2 中的图像 2,3 Condenser Microphone Shock Mount Cord Replacement: 步骤 2 中的图像 3,3
    • Once the top cord is properly removed, remove the bottom cord.
    • Removing the final cord will disconnect the mic holder from the outer ring. Make sure the mic holder is secure and won't fall once the final cord is removed.
  3. Condenser Microphone Shock Mount Cord Replacement: 步骤 3 中的图像 1,3 Condenser Microphone Shock Mount Cord Replacement: 步骤 3 中的图像 2,3 Condenser Microphone Shock Mount Cord Replacement: 步骤 3 中的图像 3,3
    • Begin by attaching the bottom cord to the four slots attached to the mic holder.
    • Cord lengths can be adjusted after it has been attached to the four slots.
  4. Condenser Microphone Shock Mount Cord Replacement: 步骤 4 中的图像 1,2 Condenser Microphone Shock Mount Cord Replacement: 步骤 4 中的图像 2,2
    • Once the bottom cord is securely attached, attach the top cord the same way.
  5. Condenser Microphone Shock Mount Cord Replacement: 步骤 5 中的图像 1,3 Condenser Microphone Shock Mount Cord Replacement: 步骤 5 中的图像 2,3 Condenser Microphone Shock Mount Cord Replacement: 步骤 5 中的图像 3,3
    • Next, take the mic holder and center it in the middle of the outer ring.
    • Take the bottom cord loops and string them on the outer rings' hooks.
    • Each cord hoop should be about the same length so that the mic holder is centered in the outer ring.
    • It is easier to string opposite cord hoops first rather than stringing them consecutively.
  6. Condenser Microphone Shock Mount Cord Replacement: 步骤 6 中的图像 1,3 Condenser Microphone Shock Mount Cord Replacement: 步骤 6 中的图像 2,3 Condenser Microphone Shock Mount Cord Replacement: 步骤 6 中的图像 3,3
    • Flip the parts over so the top is facing up and hook the top cord onto the outer ring.
  7. Condenser Microphone Shock Mount Cord Replacement: 步骤 7 中的图像 1,2 Condenser Microphone Shock Mount Cord Replacement: 步骤 7 中的图像 2,2
    • Once both of the cords are secure, you may reattach the shock mount to the mic stand.
    • Be sure the cords are secure and won't snap off before reattaching your microphone.
  8. Condenser Microphone Shock Mount Cord Replacement: 步骤 8 中的图像 1,2 Condenser Microphone Shock Mount Cord Replacement: 步骤 8 中的图像 2,2
    • Carefully reattach your condenser microphone to the shock mount to make sure the cords are connected properly.
    • Once it is confirmed that the cords are attached securely, use your shock mount at your leisure.
终点
另外一个人完成了本指南。
Avery Kwong
于09/29/15注册
141 声望
撰写一个指南
团队
Cal Poly, Team 17-3, Green Fall 2015 Cal Poly, Team 17-3, Green Fall 2015 的会员
CPSU-GREEN-F15S17G3
4 名成员
创作了3篇指南
一条评论
Where do you get the replacement cord?
Steve Hynes - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 28
总计 8,964
