跳转到主内容
Conair True Glow Lighted Mirror LED Bulb Replacement
你所需要的
  1. Conair True Glow Lighted Mirror LED Bulb Replacement, LED Bulb: 步骤 1 中的图像 1,1
    • Unplug and remove batteries to make sure the ring light does not turn on while repairing.
  2. Conair True Glow Lighted Mirror LED Bulb Replacement: 步骤 2 中的图像 1,3 Conair True Glow Lighted Mirror LED Bulb Replacement: 步骤 2 中的图像 2,3 Conair True Glow Lighted Mirror LED Bulb Replacement: 步骤 2 中的图像 3,3
    • Remove the two 2 mm screws on the side of the ring mirror (one on each side) using a Phillips #00 screwdriver.
  3. Conair True Glow Lighted Mirror LED Bulb Replacement: 步骤 3 中的图像 1,1
    • Push the cover towards you and slide away from the rest of the mirror.
  4. Conair True Glow Lighted Mirror LED Bulb Replacement: 步骤 4 中的图像 1,1
    • Using your hands, gently unscrew the old LED light bulb in a counter-clockwise direction.
  5. Conair True Glow Lighted Mirror LED Bulb Replacement: 步骤 5 中的图像 1,1
    • Use your hands to screw in the new LED light bulb in a clockwise direction.
  6. Conair True Glow Lighted Mirror LED Bulb Replacement: 步骤 6 中的图像 1,1
    • Take the cover and push it back down in place.
  7. Conair True Glow Lighted Mirror LED Bulb Replacement: 步骤 7 中的图像 1,1
    • Screw in the two 2 mm screws on each side of the mirror using a Phillips #00 screwdriver.
  8. Conair True Glow Lighted Mirror LED Bulb Replacement: 步骤 8 中的图像 1,1
    • Plug the mirror in and reinsert batteries to turn it on.
  9. Conair True Glow Lighted Mirror LED Bulb Replacement: 步骤 9 中的图像 1,1
    • Enjoy your fixed LED ring mirror light!
终点
另外一个人完成了本指南。
Dave Inthavong
于01/19/21注册
216 声望
撰写一个指南
团队
一条评论
What to do to get over to release. I’ve taken the screws out but cannot get the cover to release.
Bonnie Smith - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 59
总计 2,615
