跳转到主内容
Conair Infiniti Pro Model 259NP Fan Grill Replacement
你所需要的
  1. Conair Infiniti Pro Model 259NP Fan Grill Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
  2. Conair Infiniti Pro Model 259NP Fan Grill Replacement: 步骤 2 中的图像 1,2 Conair Infiniti Pro Model 259NP Fan Grill Replacement: 步骤 2 中的图像 2,2
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
  3. Conair Infiniti Pro Model 259NP Fan Grill Replacement: 步骤 3 中的图像 1,3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: 步骤 3 中的图像 2,3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: 步骤 3 中的图像 3,3
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
  4. Conair Infiniti Pro Model 259NP Fan Grill Replacement, Fan Motor Assembly: 步骤 4 中的图像 1,2 Conair Infiniti Pro Model 259NP Fan Grill Replacement, Fan Motor Assembly: 步骤 4 中的图像 2,2
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
  5. Conair Infiniti Pro Model 259NP Fan Grill Replacement: 步骤 5 中的图像 1,3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: 步骤 5 中的图像 2,3 Conair Infiniti Pro Model 259NP Fan Grill Replacement: 步骤 5 中的图像 3,3
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
  6. Conair Infiniti Pro Model 259NP Fan Grill Replacement, Fan Grill: 步骤 6 中的图像 1,1
    • Hold the front panel of the hair dryer by the nozzle facing upward.
  7. Conair Infiniti Pro Model 259NP Fan Grill Replacement: 步骤 7 中的图像 1,2 Conair Infiniti Pro Model 259NP Fan Grill Replacement: 步骤 7 中的图像 2,2
    • Using your index finger push the fan grill down with moderate force.
结论
另外一个人完成了本指南。
Timothy Lo
于04/22/14注册
1,172 声望
创作了7篇指南
团队
Cal Poly, Team 10-58, Amido Spring 2014 Cal Poly, Team 10-58, Amido Spring 2014 的会员
CPSU-AMIDO-S14S10G58
4 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 1,267
