跳转到主内容
Conair Infiniti PRO Spin Air Brush Circuit Board Replacement
你所需要的
  1. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement, Circuit Board: 步骤 1 中的图像 1,1
    • Look for the black screw covers near the top of the brush. Take the covers off with flat head screw driver.
  2. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the screws that secure the brush head.
  3. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Gently take off the brush top.
  4. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Take out the black gear by pulling up.
  5. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Take the top of air filter off.
  6. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Use flat head screwdriver to pop off the bottom air filter.
  7. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 步骤 7 中的图像 1,1
    • Gently use a flat head screw driver to take of the black cover, covering the plastic shell.
  8. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 步骤 8 中的图像 1,1
    • Using your flat head screwdriver to go along the seams of the plastic shell till the shell pops apart.
  9. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 步骤 9 中的图像 1,1
    • Then take the switch cover and buttons off.
  10. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 步骤 10 中的图像 1,1
    • Then take your Philips screw driver (ph1 size head) and unscrew the circuit board. The screw is located in the middle of the board.
  11. Conair Infiniti PRO Spin Air Brush Circuit Board Replacement: 步骤 11 中的图像 1,1
    • Remove the black heater cover by sliding it off.
    • Desolder each of the four connections, and remove the circuit board.
结论
另外一个人完成了本指南。
andrew shirley
于08/23/17注册
337 声望
创作了2篇指南
团队
IUPUI, Team S1-G3, Freund Fall 2017 IUPUI, Team S1-G3, Freund Fall 2017 的会员
IUPUI-FREUND-F17S1G3
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 4
过去 30 天: 38
总计 596
