跳转到主内容
Conair Infiniti PRO Curling Iron Motherboard Replacement
你所需要的
  1. Conair Infiniti PRO Curling Iron Motherboard Replacement, Housing: 步骤 1 中的图像 1,1
    • Remove the Philips #1 28 mm.
    • Make sure device is unplugged and cool before attempting to replace parts.
  2. Conair Infiniti PRO Curling Iron Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the Philips #1 22 mm screws.
  3. Conair Infiniti PRO Curling Iron Motherboard Replacement: 步骤 3 中的图像 1,3 Conair Infiniti PRO Curling Iron Motherboard Replacement: 步骤 3 中的图像 2,3 Conair Infiniti PRO Curling Iron Motherboard Replacement: 步骤 3 中的图像 3,3
    • Pry off the housing using a plastic spudger.
  4. Conair Infiniti PRO Curling Iron Motherboard Replacement, Power Cord: 步骤 4 中的图像 1,1
    • Pull power chord out.
  5. Conair Infiniti PRO Curling Iron Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Heat up your soldering gun and desolder the red wire from the motherboard as shown.
    • Note the location of wire attachment.
  6. Conair Infiniti PRO Curling Iron Motherboard Replacement: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    Desoldering Pump
    $3.99
    购买
    • With your soldering gun, desolder the white wire from the motherboard as shown.
  7. Conair Infiniti PRO Curling Iron Motherboard Replacement: 步骤 7 中的图像 1,1
    • Once both wires are desoldered the motherboard can be removed.
结论
To reassemble your device, follow these instructions in reverse order, making sure to resolder the wires correctly into the replacement motherboard.
2等其他人完成本指南。
Jonathon Bruer
于11/09/17注册
607 声望
创作了5篇指南
团队
IUPUI, Team S7-G5, Baechle Fall 2017 IUPUI, Team S7-G5, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S7G5
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 585
