跳转到主内容
Conair Cord-Keeper 169XR On/Off Switch Replacement
你所需要的
  1. Conair Cord-Keeper 169XR On/Off Switch Replacement, Handle Cover: 步骤 1 中的图像 1,2 Conair Cord-Keeper 169XR On/Off Switch Replacement, Handle Cover: 步骤 1 中的图像 2,2
    • Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
  2. Conair Cord-Keeper 169XR On/Off Switch Replacement: 步骤 2 中的图像 1,1
    • Be cautious of pieces that can possibly fall out when removing the face of the handle.
    • Once you have taken the screws out, take the top half of the handle off by lifting it off of the dryer.
  3. Conair Cord-Keeper 169XR On/Off Switch Replacement, On/Off Switch: 步骤 3 中的图像 1,2 Conair Cord-Keeper 169XR On/Off Switch Replacement, On/Off Switch: 步骤 3 中的图像 2,2
    • Now take out the On/Off switch by gently pulling it out towards you and lightly pushing it to the right with your finger until it comes out of the groove it is resting in.
    • Once the new switch is in place you can put the dryer back together.
结论
3等其他人完成本指南。
Candace
于01/23/14注册
992 声望
创作了7篇指南
团队
Cal Poly, Team 10-33, Maness Winter 2014 Cal Poly, Team 10-33, Maness Winter 2014 的会员
CPSU-MANESS-W14S10G33
3 名成员
创作了7篇指南
3条评论
Looks to me that a replacement switch would be required. How can obtain one?
Jaky Felix - 回复
“No parts required” is what’s displayed by default when there’s no link to an actual part for sale—it’’s a bit silly and clearly incorrect in this case. For hard-to-find parts, check eBay or Amazon. Also, a lot of folks with multiple broken units use these guides to cobble together one working unit from the parts. Good luck!
Jeff Suovanen -
That was my question, where can I get a replacement switch?
Constance Hudson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 3,050
