When removing the coil, make sure it stays wound up. It could very easily pop out, and you would have to wind it all the way back up and try to squeeze it back into the slot when you reassemble the dryer.
To remove the coil, use your screw driver to pop the coil out of the slot.
The second image is what the coil would look like if it came undone when you removed it.
