跳转到主内容
Computer King Muffin Kinder 7 Screen Replacement
你所需要的
  1. Computer King Muffin Kinder 7 Screen Replacement, Screen: 步骤 1 中的图像 1,2 Computer King Muffin Kinder 7 Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Use the plastic opening tool help push out the microSD card from the microSD slot.
  2. Computer King Muffin Kinder 7 Screen Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
  3. Computer King Muffin Kinder 7 Screen Replacement: 步骤 3 中的图像 1,2 Computer King Muffin Kinder 7 Screen Replacement: 步骤 3 中的图像 2,2
    • Unscrew the nine 3.0 mm Phillips #00 screws.
  4. Computer King Muffin Kinder 7 Screen Replacement: 步骤 4 中的图像 1,1
    • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic
  5. Computer King Muffin Kinder 7 Screen Replacement: 步骤 5 中的图像 1,2 Computer King Muffin Kinder 7 Screen Replacement: 步骤 5 中的图像 2,2
    • There will be a black strip connected to the screen.
    • Use the pointy end of the spudger to unstick the black strip that is glued onto the screen.
  6. Computer King Muffin Kinder 7 Screen Replacement: 步骤 6 中的图像 1,3 Computer King Muffin Kinder 7 Screen Replacement: 步骤 6 中的图像 2,3 Computer King Muffin Kinder 7 Screen Replacement: 步骤 6 中的图像 3,3
    • You will need to remove 2 ribbon cables, one that is connected to the touch screen (by the battery) and one that is connected to the yellow plastic (by the speaker).
    • Use the flat end of the spudger to lift the black panel covering the ribbon cables.
  7. Computer King Muffin Kinder 7 Screen Replacement: 步骤 7 中的图像 1,1
    • Pull the two ribbon cables out so that they are no longer connected to the logic board.
  8. Computer King Muffin Kinder 7 Screen Replacement: 步骤 8 中的图像 1,1
    • Lift up the logic board and black plastic so that they are no longer covering the screen
    • Lift out the screen.
结论
3等其他人完成本指南。
Katherine
于01/22/15注册
439 声望
创作了3篇指南
团队
UWT Liner: Group 2 UWT Liner: Group 2 的会员
Community
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 540
