跳转到主内容
Compaq iPAQ Pocket PC 3830 Speaker Replacement
你所需要的
  1. Compaq iPAQ Pocket PC 3830 Speaker Replacement, Speaker: 步骤 1 中的图像 1,2 Compaq iPAQ Pocket PC 3830 Speaker Replacement, Speaker: 步骤 1 中的图像 2,2
    • Remove the four 0.8mm Phillips # 00 screws from the back board using the screwdriver from your tool kit.
  2. Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 2 中的图像 1,2 Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 2 中的图像 2,2
    • Once the backboard is removed, remove the four screws on the motherboard. Two on top of the motherboard and two on the bottom of the motherboard using the Phillips screwdriver.
  3. Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Detach the two pairs of wires, found on the top right of the motherboard, from their combs using the tweezers from the toolkit.
  4. Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 4 中的图像 1,2 Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 4 中的图像 2,2
    • In order to get to the speaker, try to free the motherboard by removing all the wires from their combs using the tweezers.
  5. Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 5 中的图像 1,2 Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 5 中的图像 2,2
    • Use tweezers to remove wires from combs.
  6. Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 6 中的图像 1,1
    • Use your tweezers to free wire from comb in order to free the motherboard.
  7. Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 7 中的图像 1,1
    • Once you have all the wires freed from the combs, you can detach the motherboard just by lifting it out of place.
  8. Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 8 中的图像 1,3 Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 8 中的图像 2,3 Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 8 中的图像 3,3
    • Unscrew the two Phillips #00 screws to get the speaker loose using a Phillips screwdriver. The screws measure 0.3 mm in length.
  9. Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 9 中的图像 1,2 Compaq iPAQ Pocket PC 3830 Speaker Replacement: 步骤 9 中的图像 2,2
    • Once the two screws that hold the speaker in place are removed, remove the speaker using tweezers.
结论
Sedina Cavcic
于09/05/14注册
464 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 347
