跳转到主内容
Compaq iPAQ Pocket PC 3830 Battery Replacement
你所需要的
  1. Compaq iPAQ Pocket PC 3830 Battery Replacement, Remove four screws from back cover: 步骤 1 中的图像 1,2 Compaq iPAQ Pocket PC 3830 Battery Replacement, Remove four screws from back cover: 步骤 1 中的图像 2,2
    • Remove the four 0.8 mm Phillips #00 screws from the back cover.
  2. Compaq iPAQ Pocket PC 3830 Battery Replacement: 步骤 2 中的图像 1,1
    • Detach the yellow wire from comb that is attached to the battery.
  3. Compaq iPAQ Pocket PC 3830 Battery Replacement: 步骤 3 中的图像 1,1
    • The yellow wire is removed from the comb attached to the battery.
  4. Compaq iPAQ Pocket PC 3830 Battery Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the battery using tweezers from back cover.
  5. Compaq iPAQ Pocket PC 3830 Battery Replacement: 步骤 5 中的图像 1,1
    • Detach the battery from back cover.
结论
3等其他人完成本指南。
Sedina Cavcic
于09/05/14注册
464 声望
创作了3篇指南
团队
2条评论
One question; Where can I get a new battery????
Every place I have looked have a smaller batter,  not like the one you show.
Stephen
oharasc85@gmail.com
Stephen O'Hara - 回复
we are in need of battery
Danionics DLP 305590
Quantity : 02 Nos.
Please send us the lowest estimate.
Mail ID: electronics@pmtpims.org
ELECTRONICS1 PIMS - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 40
总计 3,172
