跳转到主内容
Compaq Presario V2414NR RAM Replacement
你所需要的
  1. Compaq Presario V2414NR RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR RAM Replacement: 步骤 2 中的图像 1,2 Compaq Presario V2414NR RAM Replacement: 步骤 2 中的图像 2,2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR RAM Replacement, RAM Cover: 步骤 3 中的图像 1,2 Compaq Presario V2414NR RAM Replacement, RAM Cover: 步骤 3 中的图像 2,2
    • Loosen the two 5mm Phillips #1 screws that secure the memory module compartment cover to the computer.
    • These screws are captured to the cover panel.
    • Lift the front edge of the memory module compartment cover and swing it back to remove it.
  4. Compaq Presario V2414NR RAM Replacement, RAM: 步骤 4 中的图像 1,2 Compaq Presario V2414NR RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Use your fingers, or plastic opening tools, to spread the metal retaining tabs on each side of the RAM outwards until the module pops up.
    • Pull the module out of the socket at the same angle it is now oriented.
    • Repeat these steps to remove the second memory module.
    • When reassembling, align the offset notch on the RAM contacts with the tab on the socket and insert at a 30 degree angle.
结论
Rylie Schmidt
于04/19/15注册
765 声望
创作了7篇指南
团队
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 UMass Dartmouth, Team 2-1, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G1
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 262
