跳转到主内容
Compaq Presario V2414NR Optical Drive Replacement
你所需要的
  1. Compaq Presario V2414NR Optical Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Shutdown the computer.
    • Remove all external devices.
    • Unplug the power, and any other cords, from the laptop.
    • Turn the laptop upside down, with the front towards you.
  2. Compaq Presario V2414NR Optical Drive Replacement: 步骤 2 中的图像 1,2 Compaq Presario V2414NR Optical Drive Replacement: 步骤 2 中的图像 2,2
    • Slide the battery release latch to the left until the battery pops up.
    • Lift the front edge of the battery pack and swing it back to remove it.
    • When reassembling, first align the back of the battery with the chassis, then press the front downwards until it latches.
  3. Compaq Presario V2414NR Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 1,2 Compaq Presario V2414NR Optical Drive Replacement, Optical Drive: 步骤 3 中的图像 2,2
    • On the optical drive there is small pin hole. Insert a paperclip or similarly sized object in the hole.
    • The Drive will pop a short way out of the computer.
  4. Compaq Presario V2414NR Optical Drive Replacement: 步骤 4 中的图像 1,3 Compaq Presario V2414NR Optical Drive Replacement: 步骤 4 中的图像 2,3 Compaq Presario V2414NR Optical Drive Replacement: 步骤 4 中的图像 3,3
    • Remove the 7mm Phillips #1 screw that secures the optical drive to the computer.
    • Grip the sides of the Optical Drive and slide it out until it is completely removed from the computer.
    • When reassembling, slide the optical drive straight in until it clicks.
结论
Rylie Schmidt
于04/19/15注册
765 声望
创作了7篇指南
团队
UMass Dartmouth, Team 2-1, Isaacson Fall 2016 UMass Dartmouth, Team 2-1, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G1
3 名成员
创作了9篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 7
总计 205
